I'm using AutoCAD Mechanical 2013. I attempted to open igs & stp files with Inventor Fusion. The result, many common used functions in Mechanical has become DOS mode.
Eg. When I key in saveas, it will prompt me on the command line to sellect which version, then key in the entire path of the new file to be kept.
Can some experts share how to resolve it? MTIA
Solved by DarrenP. Go to Solution.
fileDia press enter then type in 1
try typing that into the command line
DarrenP
You're a god sent! Issue resolved! Thanks a million!
Can share what the problem was? Wanna learn more....
Another issue: I can't open the Layer manager dialog box
It prompted me to enter Layer/Object keys
