AutoCAD Mechanical General Discussion
Panygeric
Message 1 of 11 (591 Views)
AutoCAD Mechanical->"FACTORY ASSETS" Inquiry
591 Views, 10 Replies
06-12-2012 07:40 AM
Hopefully I'm in the correct forum section for this  - I currently have open a "facility layout" 2D test drawing in AutoCAD Mechanical 2012
This 2D drawing will then be "Sent To Inventor" to become a 3D viewable floor layout in Inventor 2012 Factory Design Suite
*On the right side of my screen (in the 2D version) is the Asset Browser window
*I have been able to bring-up icons indicating "Cloud-Based Assets" which appear in the browser window - altho their specific icons seem to be missing - instead only a "filler" type icon.
*I can click on these assets and get a message that the asset is forever "downloading" altho nothing happens...
*Ultimately I only get a message indicating: "Cloud assets are unavailable you can use previously downloaded assets"
I'm wondering what the nature of this problem might be.... Internet connectivity? Program installation?
Appreciate any help or suggestions!! :smileyhappy:
Distinguished Contributor
nstalker
Message 2 of 11 (543 Views)
Re: AutoCAD Mechanical->"FACTORY ASSETS" Inquiry
09-12-2012 08:45 AM in reply to: Panygeric
I am having the same problem.  I used to be able to download them a few weeks ago but I can't anymore.
Employee
jeff.pek
Message 3 of 11 (533 Views)
09-13-2012 10:51 AM in reply to: Panygeric
Hi -
Sorry you're seeing these problems.
We have had some issues with the servers, etc. that manage the Cloud-based assets. Hopefully those have been resolved. Are you still seeing these errors?
If so, one thing that you can try is to empty the local library where the cloud assets are downloaded to, and see if perhaps there's some corruption there that's causing problems. This action is available in the Factory Options dialog.
Cheers,
  Jeff
nstalker
Message 4 of 11 (531 Views)
09-13-2012 10:54 AM in reply to: jeff.pek
Jeff - I hit the refresh button several times and then it finally connected.  Thank you for your response!
Active Member
boojie_recto
Message 5 of 11 (450 Views)
04-21-2013 11:14 PM in reply to: nstalker
Hi! I have been having this problem for quite some time now. I did not pay attention to this not until I found my self in need of other factory assets. It seems like my pc cannot connect to the server where the cloud assets are located. Could this be due to my connection? I am using FDS 2013 Premium. I also attached the icon that displays on my assests browser window.
Employee
jeff.pek
Message 6 of 11 (442 Views)
04-22-2013 03:18 AM in reply to: boojie_recto
Hi -
Sorry you're having this problem.
Can you try pasting the following URL into a browser, and see if you get any result?
http://api.autodesk.com/shared/AZlcrIy
  Jeff
Active Member
boojie_recto
Message 7 of 11 (436 Views)
04-22-2013 05:32 PM in reply to: jeff.pek
Hi Jeff, I tried pasting the URL on internet explorer but i just get a bunch of html codes of some sort. I tried it on chrome but all it did was download an xml file whcih contain the same codes (i think their the same).
Employee
jeff.pek
Message 8 of 11 (432 Views)
04-22-2013 05:35 PM in reply to: boojie_recto
Hi again -
That's good -- that's actually what should happen :-).
So you don't have a general connectivity problem with the machines hosting the assets.
The next steps may be trickier, depending on what you're comfortable with.
If you'd like, I (or someone on our team) can spend a little time with you to see if we can see what's happening.
Are you willing to spend some time with someone in a screensharing session?
What country are you in?
  Jeff
Active Member
boojie_recto
Message 9 of 11 (429 Views)
04-22-2013 05:48 PM in reply to: jeff.pek
I see. I'm from the Philippines.
Employee
XuesongBai
Message 10 of 11 (399 Views)
04-22-2013 07:49 PM in reply to: boojie_recto
Hi there,
Sorry for the inconvenience that taken to you.
I am from the developement of FDS at Shanghai. So could you please let me demote your machine to look closed at the issue?
My email is Xuesong.bai@autodesk.com. You can contact me directly if you are available.
-Xuesong
