AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
AutoCAD Mechanical AMREVLINE behavior
5 REPLIES 5
523 Views, 5 Replies
I am setting up a standards DWT file and require:
  • 4 different borders (A,B,C,D size)
  • 4 different titleblocks (A,B,C,D size)
  • 2 different revision block types (A size, all others)
The problem is that when I add a line to the revision via AMREVLINE there seems to be 4 ways of doing so and each yields different results.
Start the AMREVLINE command then:
  1. press enter for global
  2. select the border
  3. select the titleblock
  4. select one of the previous lines
The behavior is different for each of the different layouts I create via AMTITLE.
test one: no selection on initial insertion (global)
          none     border     titleblock     revline
a          new     new          new          new
b          new     adds          adds          new
c          adds     new          new          adds
d          adds     new          new          adds
test two: border selection on initial insertion
same results as above
The new revision row will either be added to the prior list or create a new one.
What are the rules of AMREVLINE row addition?
TomPy
5 REPLIES 5
Sridhar-Autodesk
Global Space will insert a new revline always.  Whereas Border/Titleblock will add a revline to the last inserted revline.
Please see below example.
Scenario-1
  1. Insert a revline using Global (P1)
  2. amrevline>>Select Border/Titleblock>>will add to the revline inserted in step-1
Scenario-2
  1. Insert a revline using Global (arbitrary P1)
  2. amrevline>>Select Border/Titleblock>>will add to the revline inserted in step-1 (will add to P1)
  3. Insert a revline using Global (arbitrary P2)
  4. amrevline>>Select Border/Titleblock>>will add to the revline inserted in step-3 (will add to P2)
Therefore use Global option only when you insert a revline for the first time.  Thereafter, I would suggest you to use Border/Titleblock option to add subsequent revlines.
Hope this helps
Sridhar Subramani
Senior Product Owner
in reply to: Sridhar-Autodesk
In your Scenario-1, two of my four sizes are working as you suggest and two are not.
C & D sizes are working perfectly.
However, the A & B sizes are not.
I did a further test using the following:
D Titleblock with B Border = Works as you have described
B Titleblock with D Border = Works as you have described
A Titleblock with D Border = Works as you have described
D Titleblock with A Border = Works as you have described
But
B Titleblock with B Border = just keeps adding new revline sets
A Titleblock with A Border = just keeps adding new revline sets
My method for the test was:
  1. start a new file
  2. AMTITLE (selecting the appropriate border/titleblock)
  3. AMREVLINE (hitting 'return' for global space, type in a revision number, place the revision line set via snapping to a titleblock line)
  4. AMREVLINE (selecting the previously added Revision line, typing in the next revision number)
Any ideas why I could be seeing this behaviour?
TomPy
Sridhar-Autodesk
In your method of test, on step 3 and 4, can you always select Border (instead of Global) and verify if it adds a revline to previous one?
Sridhar Subramani
The issue is that the behaviour is different for C and D sizes. What is the issue with the different behaviour for the different sizes?
I am very tired of chasing this issue in circles. can I send someone a data set and have thenm just solve it?
Tom
Sridhar-Autodesk
Can you zip and attach the file to this thread or send them at sridharDOTsubramaniATautodeskDOTcom
Also let me know AutoCAD Mechanical version and operating system.
Sridhar Subramani
”Boost
