AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
autocad mechanical 2015-problem opening drawing from explorer
5 REPLIES 5
pmapi123
348 Views, 5 Replies
the only way i can open a .dwg is by opening Autocad Mechanical 2015 and than surf thru the program. how can i open any dwg from explorer by douyble clicking? i have reinstalled the software twice. attachments represents when opening thru explorer
5 REPLIES 5
Jacob_Butler
in reply to: pmapi123
__________________________________________________
Autodesk Certified Professional - Inventor
Jacob_Butler
Right click the dwg and then try setting the default program to be dwg launcher.
pmapi123
in reply to: Jacob_Butler
didnt work
acwtzwegers
Since release 2015 you need to ignore the DWGLauncher and setup AutoCAD Mechanical to launch directly.
So: in windows, right click on a dwg, open with, choose default program, autocad application.
pmapi123
in reply to: acwtzwegers
i have done that and when i select the default option it gives me 1st issue 1 and than 2nd screen.
”Boost
