Autocad mechanical 2014 3d dynamic blocks
Is there some way to show a positional representation of a 3d assembly in autocad?  For example, if you wanted to show a backhoe arm in is different positions.  Could dynamic blocks achieve this? This is no problem in inventor, but my customer only works in autcad.
steve216586
This user had the same question, although it was in 2D. Maybe it can help you.
http://forums.autodesk.com/t5/autocad-2010-2011-2012/rotating-block-with-attached-lines/m-p/5862992#...
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Thanks steve216586, I'm picking up on this project this week. The above is similar to my situation. I'll let reply back how this turns out.
I have a way to do it in Autocad. Im actually using it for a long time already. I normally used it for technical study. i.e plant reaching capacity, animation etc.. here's how to do it.
Let say you have 3d PLANT (BACK HOE for example)
; you want your 3d backhoe to move its Bucket, then the parameter and action for ROTATE will work in 3D- not a problem
Let say you want to have a 3d dyamic block of Lorry crane where the boom is stretchable.
is too easy. (applicable to all 3d solid model that required stretching for ease of use etc.)
here is what you need to do if you have 3d solid of Lorry crane ;
- type Smooth command
- select the boom of the lorry crane(or any)
- then click ok ( the solid will turn to be a mesh)
- select the boom, then go to properties and change the smoothness to NONE.
then start making dynamic block.
-make block( 3d solid lorry crane plus the boom which became mesh .)
- open block editor
- set linear parameter for the boom
- set stretch action to the boom.
- then close.
then try it .
the boom is stretchable. (you can actually combine with rotate parameter if you wish)
im sure it will work.
if you wish to turn back the mesh in to solid. you could do that by the command convtosolid.
cheers
Thanks for the help
Legend...followed these instructions and all parameters work perfectly.
