My AutoCAD Mechanical is telling me there's an update available.
I tried using the link from within AutoCAD, but security seems to be cranked up too high on my computer to let whatever ActiveX or script it's using run.
Searching for "AutoCAD Mechanical 2013 Service Pack 2" doesn't find it. Only SP1. Does anyone have a link where I can see what it covers and download it?
Solved by Sridhar-Autodesk. Go to Solution.
sp 2 isn't out yet
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240898
DarrenP
Hi Bill,
As of now, we can download AutoCAD Mechanical 2013 SP2 only through live update. I will update you once it is posted on the following link.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240898#section2
AutoCAD Mechanical 2013 SP2 is posted on the following link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21818160&siteID=123112&linkID=9240898
Thanks!
Do the updates from within AutoCAD use Java? If so, that may be why it didn't work for me. Our IT department has had everyone uninstall Java for security reasons.
