When I use autocad mechanical 2013 to copy some lines to autocad mechacal version 2012 using ctr+C copyclip and ctr+P pasteclip, for previous version the the line will be still a line in the lower version., but now it will be inserted as an object/ May I know what is the reason?
Same problem when I copy some sketch to Solidworks, with old version I can copy the sketch into solkdworks directly, but now it now working? Why?
It seems like there is an issue in AutoCAD 2013. I have already reported this to our development team. I will keep you posted once I have some updates.
Are you using Ctrl+C and Ctrl+V. Then it will paste as OLE. This is as designed and it works the same in 2012. I also checked the same in 2008. Could you please tell us the older version in which it used to work differently.
I'm using autocad mechanical 2012 and 2013. I've using version 2012 for long time lready. Never meet this problem. Yes I'm using Ctr+c and Crt+v. But In previous version this problem will not hapen. And also if I copy and past a sket from Autocad to Solidworks 2D sketch. Version 2012 is possible to copy directly. but in version 2013 I can not do.
