hi,
I am using AutoCAD Mechanical 2012 which is not having Help file installed. is there any other way(s) to get the help file for the same online?
Raviraj
Solved by celine.manca. Go to Solution.
Hi Raviraj,
I've marked Celine's reply as a solution to your question.
I'd like to give you some additional information.
Go to Options > Systems > Autodesk Exchange.
By default, offline help can be accessed from C:\Program Files\Autodesk\AutoCAD Mechanical 2012\Help\landing.html.
