AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
AutoCAD Mechanical 2012 Help File
2 REPLIES 2
762 Views, 2 Replies
hi,
I am using AutoCAD Mechanical 2012 which is not having Help file installed. is there any other way(s) to get the help file for the same online?
Raviraj
2 REPLIES 2
celine.manca
Hi Raviraj,
There is an online help only for the 2012 release of AutoCAD Mechanical.
You can find it here.
Celine Manca
inchul.lee
in reply to: celine.manca
Hi Raviraj,
I've marked Celine's reply as a solution to your question.
I'd like to give you some additional information.
Go to Options > Systems > Autodesk Exchange.
  • You can choose whether or not to access Autodesk Exchange when the Internet connection is available.
  • And you can also choose which Internet browser will be used to open offline help.
By default, offline help can be accessed from C:\Program Files\Autodesk\AutoCAD Mechanical 2012\Help\landing.html.
Inchul Lee
”Boost
