AutoCAD Mechanical General Discussion
Member
gojo
Message 1 of 4 (2,619 Views)
AutoCAD Mechanical 2012 Grid Display Settings and contentlib.xml file
2619 Views, 3 Replies
03-20-2012 11:06 AM
Does anyone know how to keep the grid display turned off when opening up the program each time?  I just went from AutoCAD Mechanicl 2010 on a Windows XP 32 bit OS to AutoCAD Mechanical 2012 on a Windos 7 64 bit OS.  Everytime i open AutoCAD the grid disply is on....it wont stay turned off.  Also everytime i start up AutoCAD i get this error message sying it can't find the "contentlib.xml" file in the location under Document and settings.....\Gdb.  it is looking for the 2011 version of this file.  I t already has the 2012 version of this file.  Does anyone know how to direct it to look at the 2012 version and ignore the 2011.  I have never had earlier versions of AutoCAD intalled on this machine, so don't know why it is looking for and older file.
Product Support
Matt.Desfosses
Message 2 of 4 (2,587 Views)
Re: AutoCAD Mechanical 2012 Grid Display Settings and contentlib.xml file
03-23-2012 07:50 AM in reply to: gojo
The grid is controlled through your template file (.DWT).  If you open up your template file and turn the grid off and then save the template file the next time you launch that template the grid will be off.
Matt Desfosses
Support Specialist
Product Support
Employee
Sridhar-Autodesk
Message 3 of 4 (2,564 Views)
03-27-2012 02:42 AM in reply to: gojo
You may modify the contentlib.xml location using following steps:
1. Command amcontentmanager
2. Click on File Locations Button
3. Click the ... button and point to the default location shown in the attached image.
4. Click Save and Close button
5. Close AutoCAD Mechanical and Relaunch and verify the issue.
Sridhar Subramani
Member
gojo
Message 4 of 4 (2,558 Views)
03-27-2012 07:58 AM in reply to: gojo
Sridhar Subramani,
That worked perfect.  thank you very much.
