In at least one workstation with Inventor 2012 installed I cannot connect to the Vault recently moved to version 2013.
All others (Inventor 2012, Vault Client 2012) connects fine, but Mechanical 2012 won't. Always pops up "Server not found". I don't get even the list of vault stores.
That seems to be an issue with the Windows firewall on the server. If the firewall is switched off all runs fine. Good.
But I wanted to know what other port(s) than port 80 uses Mechanical to set the firewall correct.
