When I used Mehcanical 2009 I could draw a box around objects, right click, copy, then paste them wherever I needed. Now with new 2011 Mechanical version it won't let me unless I right click and chose copy, move, rotate from the move option. When I right click and chose copy it wants me to click on every single line. Any ideas?
Blair
Hi, Blair
Please try following steps:
Command CUI>>Customize Tab>>on the left hand side, expand "Shortcut Menus">>Expand "Edit Menu">>under "command list" search for "Copy Selection">>Select the button, Drag and Drop into the Edit Menu
Find attached image for more info
Hope this helps
