Hi everyboby,
I have a problem; I was installed AutoCAD Mechanical 2010 on Win 7 Pro (x64) OS but its not running.
AutoCAD Error Aborting : FATAL ERROR: Unhandled e0434f4dh Exception at fd49cacdh. Has anyone with this error code before? Does anyone know the path to the solution of this problem?
Thanks for your coorperation.
Have you experienced the error right after you try to launch the product?
If so, have you tried Re-install to see whether it's gone or not?
At the same time, did you send the error report by filling your email and comments? If not, please do so and let me know your emal address for further investigation.
Hi Michail Su,
First, thank you for your help.
I was solved this problem. The program gives this error when using the local language and settings. I changed the language settings and now it works in the English language and settings.
I think that it should work the local language and settings. In my opinion would be useful in this regard the publication of a new service pack.
