AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
AutoCAD Mech 2010 will not start - just seeing the p[lash screen
1 REPLY 1
373 Views, 1 Reply
I have a Dell M6500 computer using autodesk mech 2010 with a lic server server.  When click on the the autodesk 2010x64 icon I just get the flash screen for a second and it goes back to the program icon.  I tried on and off the network with the sam eresult.  I also tried installing the 2010 update 1 & 2 and it tells me it can't find the software to do the update.  I see the dir with the files on the the C: drive. any thoughts?
1 REPLY 1
VinodBalasubramanian
What version of OS you have ?
Can you turn off any anitivirus that's running on your machine. You can use the following solution to turn it off temporarily for testing.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7313059&linkID=9242018
If you are using Windows 7 or Vista, can you go to Control Panel -> user accounts -> Change User account control settings and turn off UAC. Then test launching your AutoCAD Mechanical.
Sometimes profile corruption can cause such problems. Try creating a new user login in Windows with local administrator rights and launch the software in that login.
Hope it helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Tags (2)
”Boost
