Can someone help to convert the attached .DWG file to IGES format (Solid?)? I need it for VMC machining. I do not have autocad and don't know how to do it.
Thanks in advance.
- Kedar
Iges file attached. DWG is 2D, is that what you wanted converted ?
V.
Hi V.Page,
Thanks for your help. I am not conversent with the terminology. When you say it is 2D, did you expect a 3D autocad file for converting it in IGES?
The files which you gave me (.XLO, .XLI and .IGS) are those sufficient for the machining? I can not see the contents of those.
Please reply
Regards
- Kedar
Basically in 2D it is just the same as the paper drawing but in another format. The machinist could possibly use one of the views as a start point and program in the 3rd dimension manually. Ideally the IGES file would be a model, converted from an AutoCAD model.
V.
Hi...Is it possible that you can send me the Monitor.zip, Monitor2.zip, and the Desk.zip files to my email johnosxy@yahoo.com?
Thank you very big,
John
Hello. I have created a .dwg file in AutoCad 2005 but my machinist needs an Iges file...... can anyone please convert this to an Iges file? Any help is greatly appreciated. Thanks.
Tim
