AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Autocad 2013 Freezing
2 REPLIES 2
1358 Views, 2 Replies
Low Down:
Windows XP on a Dell Laptop 2GB RAM
Autodesk Inventor Pro w/ Mechanical CAD (Network License)
Problem:
CAD freezes up but not completely. You can use the icon buttons, but you cannot type in commmands, hot keys or switch tabs between layouts.
Any ideas?
2 REPLIES 2
TravisNave
You're probably running at the bare minimum system requirements which is going to affect how well the software responds.  I suggest installing it on a newer machine with more RAM and preferably 64-bit.
Autodesk Forums:
Steve_Bessette
The following link (http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534) will bring you to the Autodesk Certified Hardware website.  Here you can confirm that you are using a system that is sufficient to run the program in question.
May I also suggest that you preform a repair of your program.  This can be done by
  • opening the Control Panel
  • Uninstall Programs
  • Click on AutoCAD Mechanical 2013
  • Click "Uninstall/Change"
  • Click "Repair or Reinstall" in the AutoCAD Mechanical 2013 dialog box
  • Make sure the "Repair" option is highlighted under the "Repair or reinstall AutoCAD Mechanical 2013:" header and click "Repair"
If this solution is sufficient, please check "Accept as Solution"
Steve Bessette
Support Specialist
Product Support
Autodesk, Inc.
”Boost
