AutoCAD Mechanical General Discussion
Valued Contributor
rcmike
Message 1 of 3 (1,129 Views)
Autocad 2013 Freezing
1129 Views, 2 Replies
07-03-2012 12:26 PM
Low Down:
Windows XP on a Dell Laptop 2GB RAM
Autodesk Inventor Pro w/ Mechanical CAD (Network License)
Problem:
CAD freezes up but not completely. You can use the icon buttons, but you cannot type in commmands, hot keys or switch tabs between layouts.
Any ideas?
TravisNave
Message 2 of 3 (1,097 Views)
Re: Autocad 2013 Freezing
07-09-2012 12:28 PM in reply to: rcmike
You're probably running at the bare minimum system requirements which is going to affect how well the software responds.  I suggest installing it on a newer machine with more RAM and preferably 64-bit.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Product Support
Steve_Bessette
Message 3 of 3 (1,085 Views)
07-11-2012 06:54 AM in reply to: rcmike
The following link (http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534) will bring you to the Autodesk Certified Hardware website.  Here you can confirm that you are using a system that is sufficient to run the program in question.
May I also suggest that you preform a repair of your program.  This can be done by
  • opening the Control Panel
  • Uninstall Programs
  • Click on AutoCAD Mechanical 2013
  • Click "Uninstall/Change"
  • Click "Repair or Reinstall" in the AutoCAD Mechanical 2013 dialog box
  • Make sure the "Repair" option is highlighted under the "Repair or reinstall AutoCAD Mechanical 2013:" header and click "Repair"
If this solution is sufficient, please check "Accept as Solution"
Steve Bessette
Support Specialist
Product Support
