AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Autocad 2012 - DWG to PDF Exporting Failure (SketchBook Designer).
2 REPLIES 2
mrm01
1180 Views, 2 Replies
When I try to export a drawing from .dwg to .pdf, I get the following message in AutoCAD Mechanical 2012:
SketchBook Designer data can only be saved in DWG file format and will be
omitted from other file types.
I have never used SketchBook Designer though it is installed on my machine.  All I want to do is create a pdf to send to someone like I've done a million times in Autocad 2010.  Does anyone know what the problem is and how to resolve it?
Thanks.
2 REPLIES 2
michaelsu
in reply to: mrm01
I think this warning message comes from SketchBook Designer addin. I guess you may have installed those products from Suite installer.
So maybe you can try to uninstall the addin of SketchBook Designer for AutoCAD and see if the message goes away. see snapshot.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Greatwhitenorth
in reply to: michaelsu
Thanks Michael.  That fixed it!
Bob
____________________________________________________
Product Design & Manufacturing Collection 2021 | Vault Professional 2021
Dell Precision 7670 | Intel i7-12850HX - 2100 Mhz - 64GB
nVIDIA RTX A3000 12GB | Windows 10/64 Pro
”Boost
