I am using AutoCAD 2011. While using 3d orbit, often the program crashes. Its hit and miss when this happens. Big or small files but always using 3d orbit. Does anyone else have this problem?
This could happen due to graphics issues. Can you check whether you have certified driver installed or not. You could use the below link to verify that.
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
You may also want to turn on hardware acceleration and see whether it helps.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5554010&linkID=9240617
