AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Autocad 2010 does not start any more
5 REPLIES 5
GeorgK
852 Views, 5 Replies
Hello together,
I have Autocad Meachnical 2010 running under Windows 7 x64. Today I got the following error:
Path to the application:
C:\Program Files\Autodesk\ACADM 2010\acad.exe
Problemsignatur Problemereignisame: BEX64
Anwendungsname: acad.exe Anwendungsversion: 24.0.309.0
Anwendungszeitstempel: 4bcbe2a9 Fehlermodulname: MSVCR90.dll
Fehlermodulversion: 9.0.30729.6161
Fehlermodulzeitstempel: 4dace4e7
Ausnahmeoffset: 00000000000552d4
Ausnahmecode: c0000417
Ausnahmedaten: 0000000000000000
Betriebsystemversion: 6.1.7601.2.1.0.256.48
Gebietsschema-ID: 1031
Zusatzinformation 1: bd9a
Zusatzinformation 2: bd9af264bf6436df1438611d6e14a9fc
Zusatzinformation 3: 2de3
Zusatzinformation 4: 2de352312c560303d49c10f213de1211
Weitere Informationen über das Problem Bucket-ID: 2046382730
I did the following:
- Repair installtion => without any change
- Dinstalltion and reinstallation => without any change
- Reapir of VC++ 2005 / 2008 / 2010 SP1 vcredist_x86; vcredist_x64)
- Delete files and folders:
    C:\Benutzer\%username%\AppData\Roaming\Autodesk
    C:\Benutzer\%username%\AppData\Local\Autodesk
    C:\ProgramData\Autodesk
Delete the registry key:
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0]
I think the problem is in one of these files:
C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c
C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251
Thank you for you help
Georg
5 REPLIES 5
Yong.Jing
in reply to: GeorgK
From System requirement, you could see ACM2010 is officially supported to be installed on Win7 64bit OS.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15458102&linkID=9240897#section8
AutoCAD Mechanical 2010 System Requirements
64-bit Requirements
  • Microsoft Windows XP Professional x64 Edition SP2 and later, or Microsoft Windows Vista (SP1 or later), including Enterprise, Business, Ultimate, and Home Premium editions
So the issue on this OS is not supported.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
GeorgK
in reply to: GeorgK
Autocad was running for month on Windows 7 x64 without any problems. I have several other computers with the same configuration. They are running very well.
How could I solve this problem?
Yong.Jing
in reply to: GeorgK
Officially, AutoCAD 2010 is not supported on Win 7 64bit OS, as it is not confirmed by Autodesk.
But for this issue, have you tried below Solutions?
For standalone license, please try  TS15176093
For network license, please try TS14908069
Yong Jing
TravisNave
in reply to: Yong.Jing
jingy,
Your information is not correct.  Though 2010 came out before Windows 7, Autodesk retroactively supported it for many of the 2010 product line, including AutoCAD 2010.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14185352
Autodesk Forums:
TravisNave
in reply to: GeorgK
Georg,
Consider doing a System Restore back to a date when you knew it was working.  It seems to be failing on your Visual C++ Redistributable prerequisite.  If repairing and reinstalling didn't fix it, consider rolling back to a date when it did work.  Perhaps you will get lucky.
Autodesk Forums:
”Boost
