I am trying to install AutoCAD Mechanical Network Version 2014 from Command line using following command.
Setup.exe /t /qb /Language en-US /c ACAD: INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014" ACADSERIALPREFIX=393
ACADSERIALNUMBER=94539329 ADLM_PRODKEY=783F1 ACADLASTNAME="User" ACADORGANIZATION=User Corporation" INSTALLLEVEL=5 ADLM_SERVER_NAME=whqsacad2k8
While instaling ti is giving us below error saying The setup is unable to validate your serial number or product key. Please run setup again via command line, using the follwoing syntax. (The follwoing should appear in one command line).
<full path to the installation setup.exe> /t /Language <product_language> /c ACAD:INSTALLDIR=<product_install_path> ACADSERIALPREFIX=<nnn> ACADSERIALNUMBER=<nnnnnnnn> ADLM_PRODKEY=<nnnnn> ACADFIRSTNAME=<first_name> ACADLASTNAME=<last_name> ACADORGANIZATION=<organization_name> InstallLevel=5
I tried to use ini file pacing the above data in setup.ini file but no luck it is giving same error. you ca see the error screen shot in the attachement.
Request you please help me in installing the software silently using commandline.
