AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Associative Detail
1 REPLY 1
270 Views, 1 Reply
Associative Detail
When I make a detail, in the dialog box, the Associative Detail area is greyed out. Any ideas as to why this would be? Standard Mechancal 2005 ANSI template (set to mm). Thanks, Bairdo
1 REPLY 1
Associative Detail is only available when you try to detail a mechanical structure folder/view. "Bairdo" wrote in message news:41cb0150$1_3@newsprd01... > When I make a detail, in the dialog box, the Associative Detail area is > greyed out. Any ideas as to why this would be? > > Standard Mechancal 2005 ANSI template (set to mm). > > Thanks, > > Bairdo > >
”Boost
