I've set up my dimensions to be annotative with 3/32" text and 3/32" arrows.
I've got my annotation scale set as 1/2" = 1'-0"
When I draw a dimension with AMPOWERDIM (the default dimension button), my resulting text and dimensions are 3/64", half of the size that they should be.
When I draw a dimension with DIMLINEAR, it is scaled correctly.
My dimstyle is "3I Standard" and there is a sub-dimstyle "Linear".
Both of these are set up as annotative.
If I go to Properties of one of the AMPOWERDIM dimensions, the dimstyle says "3I Standard$0". If I switch that to "3I Standard", then it scales correctly.
In Properties, under "Fit>>Dim Scale Overall", the AMPOWERDIM shows "0" and the DIMLINEAR shows "12".
What is going on? How do I make the power dims act like everything else? Am I missing a variable somewhere?
See last post in this thread concerning AMSCAREA command: http://forums.autodesk.com/t5/AutoCAD-Mechanical/Dimensions-ignoring-dimscale/td-p/4380271
I see similar problem in another post I replied. Hope it helps.
Let me know if you have more concerns.
