AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
AMtext7 Settings
4 REPLIES 4
npet
501 Views, 4 Replies
AMtext7 Settings
Hello!
Is there a way to change the default styles of
AMtext3.5
AMtext5
AMtext7
or this is hard coded?
For example 7 to become 6?
4 REPLIES 4
Sridhar-Autodesk
in reply to: npet
The text style is hard-coded into AMTEXT7, 5 etc commands. Thus you would have to customize own toolbars with the following macro in order to get the custom text heights.
^C^Cmtext;\h;6;
^C^Cmtext;\h;4;
Sridhar
Software QA Engineer
Manufacturing Solutions Division
Autodesk, Inc.
Sridhar Subramani
Senior Product Owner
ftsi
in reply to: npet
We need the functionality of AMText commands, which most valuable is that recognizes the scale area.
Why all companies have to work with textsize 7,5,3.5?
Pls, take care.
Thank you!
Fotis
ftsi
in reply to: npet
Pls, take care.
Thank you!
Fotis
liuyun_sg
in reply to: npet
AMTEXT commands are provided as utilities for quick access to the most common text height creation. Why these 3 (3.5, 5, and 7) are chosen is because they represent 3 typical text objects defined in Object Property Settings (AMOPTIONS->AM:Standards) that controlling layer, color, linetype and lineweight. BTW, you can change the text height during the command.
If you're looking for something more flexible, AMNOTE is probably the closest. It has a leader but can be turned off, and it works like any other Mechanical symbol text, react to scale area changes. If this still doesn't meet your requirement, can you send me an email at yun.liu@autodesk.com for more discussion?
Liu Yun
Developer
Manufacturing Solution Division
Autodesk, Inc.
Yun Liu
Principal Software Engineer
”Boost
