AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
amrectang / input search box not showing up
2 REPLIES 2
nstalker
565 Views, 2 Replies
I know I've seen this here before but I can't find the thread.  When I use the AMRECTANG command, I no longer have the option to enter the length and width and tab through the input fields.
Also the input search box is no longer available near the cursor.
I can't find the button on my toolbar that turns this on and off.
Currently filedia and cmddia are both set to 1.
2 REPLIES 2
Sridhar-Autodesk
in reply to: nstalker
Hi
Are you referring to Dynamic Input?
To enable, set system variable DYNMODE= 3
Sridhar Subramani
Senior Product Owner
Tags (1)
nstalker
in reply to: Sridhar-Autodesk
That's it!  Thanks!
”Boost
