OK, so this is only an annoyance because I am used to one method of doing something and don't want to change 🙂 ...or rather is a habbit that is proving hard to break.
I am not sure if this is a setting or if something has changed from 2012 to 2013.
Previously (Ver. 2000-2012 autocad, autocad mech), I have been able to select entities, then with those entities selected, type in a command and it will pick up those entites and carry out the rest of the command. For example: select a line, then press ctrl+shift+c, select base point, then the command finishes (copying items with a base point). Now, I select the entities, initiate the command, but the command runs as if nothing has been selected and I must select the entities again even though they are still selected (grips active).
Does anyone know if this is a setting?
Thanks in advance!
Solved by ndavis. Go to Solution.
Solved by michaelsu. Go to Solution.
Make sure PICKFIRST is set to 1 and try again. Any luck?
