AutoCAD Mechanical General Discussion
Member
0 Kudos
Post 1 of 9
ACAD Mech 2013 Properties Palette does not recognise selected objects
948 Views, 8 Replies
08-13-2012 05:50 PM
Hi all,
I have Autocad Mechanical 2013 installed in my machine. Whenever I have the properties palette open and select an object, the properties palette does not recognise the object selected.
In the item type pull-down field on the top, it remains blank and when I expand it, there is nothing to select.
All the other data fields (eg General, 3D Visualization, plot style etc) do not change.
I've tried changing the pickadd variables and the properties palette still isn't working. Even the quick properties doesn't recognise the selected objects.
Any ideas what's the problem? Autocad Mechanical 2008 still works fine for me.
Thank you.
Hi Kenny,
Just to be clear, does this issue disappears after you re-install the product?
Employee
25 Kudos
Post 2 of 9
Re: ACAD Mech 2013 Properties Palette does not recognise selected objects
08-13-2012 06:17 PM in reply to: endlesstrail
Beside AutoCAD Mechanical 2008 and 2013, what other Autodesk products have you installed? From which installer have you installed AutoCAD Mechanical 2013?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Member
0 Kudos
Post 3 of 9
08-13-2012 06:22 PM in reply to: michaelsu
Hi Michael,
I have Autocad Mechanical and Inventor 2008 installed, as well as the Autodesk Product Design Suite 2013 Standard installed.
I installed Mechanical 2013 from the USB installer which came with the PDS box.
Thanks for your quick response.
cheers,
Kenny
Employee
25 Kudos
Post 4 of 9
08-14-2012 12:40 AM in reply to: endlesstrail
Hi Kenny,
I tried to install AutoCAD Mechanical 2008 and AutoCAD Mechanical 2013 from Autodesk Product Design Suite 2013. But I could not see the issue you mentioned.
I assume the property palette never works since you installed the product, right? And it doesn't work for any type of entity, like a line? If so, maybe you can try to repair or reinstall the product in control panel to see if the issue goes away.
Also, I am wondering, have you ever used to install AutoCAD products and then uninstall them? does this issue happen to other machines?
Thanks.
Michael Su
SQA Engineer
Member
0 Kudos
Post 5 of 9
08-14-2012 05:28 PM in reply to: michaelsu
Hi Michael,
Yes, the properties palette has never worked in AMech 2013 since I installed it.
I've tried doing a repair to the Mechanical 2013 installation, but the same problem still exists.
Yes, I've done installations and re-installations of Autocad and this issue has never happened before.
Thank you.
Cheers,
Kenny
Employee
25 Kudos
Post 6 of 9
08-14-2012 05:54 PM in reply to: endlesstrail
Hi Kenny,
Thanks.
Michael Su
SQA Engineer
Member
0 Kudos
Post 7 of 9
08-14-2012 09:24 PM in reply to: michaelsu
Hi Michael,
I have tried repairing Autocad Mechanical 2013 and the problem is still there.
I have not uninstalled and reinstalled Mechanical 2013 yet. I'm trying to look for an alternative solution first, and I don't have the time to re-install it right not.
cheers,
Kenny
Member
0 Kudos
Post 8 of 9
08-15-2012 04:30 PM in reply to: endlesstrail
Fixed the problem by uninstalling and reinstalling Autocad Mechanical.
8 Kudos
Post 9 of 9
09-24-2012 11:56 AM in reply to: endlesstrail
Thanks. I am having the same trouble in Civil 3D 2013, and I see that the repair didn't get it. Good Post.
I am run running Civil 3D, Inventor, Simulation Mech, Simulation CFD, and Vault Pro. A wipe will be painful.
My problems seem to have started when my Vault retrograde went to hell, and everything is haywire.
I was trying to avoid the new OS wipe for Vault server, but now I see that there is more damage and I may have to reinstall everything.
John Evans
Autodesk Certified Professional
http://designandmotion.net
