I'm running AutoCAD Mechancial 2010 in Windows 7 64-bit and am encountering a repeatable cash. Every time I either use the save as command or run a script AutoCAD crashes the next time I try to do any command.
Given that the one thing both of these commands have in common is opening a file selection dialog box I'm guessing that the crahs is related to that but I have no clue why.
I'm running in Administrator mode and using the Windows 7 Basic theme.
Has anyone else encountered a similar issue or know a resolution?
Thanks.
