AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
2D to inventor?
2 REPLIES 2
blackwolf879
417 Views, 2 Replies
2D to inventor?
 I have atached the file I'm working on. Could any one help me? I am trying to make this a solid (that is .25" thick) do I have to make it a surface before I can make it a solid? If so how is that done?
Thank you for your help!
Nolie Scheid
Autocad Mecanical 2013
Inventor Pro 2013
Windows 7 64 bit
2 REPLIES 2
In AutoCad Mechanical, I would turn the 3 closed shapes into polylines using the pedit or bpoly commands and then the Extrude command directly into a solid.
Thank you!
”Boost
