AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
2010 Refedit
3 REPLIES 3
tgperret
1305 Views, 3 Replies
2010 Refedit
When I double click a block in 2010, bedit is the default.  How can I force a double click on a block to be refedit?
3 REPLIES 3
in reply to: tgperret
Make sure you are using AutoCAD Mechanical. " AutoCAD Mechanical 2010"
Your Quick Access Icon in the upper left hand corner Will have and A with a M in the lower lefthand corner.
If not restart your session in Autocad Mechanical.
Refedit should be the default and only works in Mechanical.
tgperret
Thanks, but refedit does work in 2010, just need to have it as the command used when a block is double clicked.  I did this modification over a year ago to change my double click to go to refedit instead of bedit in 2008 and now can't remember what I did now that we have 2010.  I do not want to work in Mechanical, but straight AutoCAD.
tgperret
I just found it:
Tools menu - Customize - Interface.... Double click actions - Block - Block Double Click. and then change the Macro and Command Display Name with refedit in lieu of bedit, will do the trick.
”Boost
