I don't know if i understand you correctly. Structure support in Design
Center has been removed since AcadM 2005. Now you can do the same thing
through structure catalog (amscatalog command). The default behavior is to
inert a folder/view as xref; However, if you hold on CTRL key while you drag
& drop a folder/view to the host drawing, a local copy will be created.
Hope this helps
Wu Tao
wrote in message news:5266226@discussion.autodesk.com...
How do you insert custom structures into drawing. I used 2004 for years and
through the designcenter you could go down the tree until you get to the
structure, then insert. 2007 designcenter doesn't have the structure
option. Is there another place to get these without placing it as an exref
through the structure catalog? Also if I do insert as exref, the structure
is individual entities and not a unit like a block. Did AutoCAD change
this? My structures are part of an assembly and are very hard to work with
individual entities which overlap with other structures. Could someone
please help in this area?
