Solved by rornelas. Go to Solution.
Unfortunately the other layers are on the top and the one that I need is under them. It doesn't let me show the one under that I need and I don't want to change the order of all the layers. Can't I just choose all the stuff that are on that layer so that it selects them right away?
AutoCAD feels very rudimentary once you use Rhino... Selecting all objects on one layer should just be a Right Click away on the Layer.
I feel Selecting objects, in general, is not a strong suit of AutoCAD.
100% accurate. I had to switch back to ACAD for a job, and I'm having Rhino withdrawals, things that were a click away are now the bulk of the time spent on a given project.
Yeah, Rhino is an absolute machine when it comes to work intuitively. I have to use autocad at work and i'm astonished how everything is so complicated, literally the whole software is awful and time-consuming. I really can't understand why schools ask students to start drawing with it. I mean rhino for students is worth 200$ and you have it for life AND is better in every way. Autodesk should delete this software asap, it would be life changing 🙂
Agreed, but we all know that Autodesk just focuses on maintaining monopoly... without the actual improvement of the software..
I've been using Rhino and have been wondering while Autocad is still dominant in 2023. Perhaps it's because of its huge marketing sector, but who knows.
