Explode Vs Ungroup
Explode Vs Ungroup
Message 1 of 14
Explode Vs Ungroup
What is the different between Explode and Ungroup command?
Replies (13)
Message 2 of 14
steve216586
Research, research, research! We're not doing your homework.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 3 of 14
First I ask my tutor. If I am not satisfied, second I search in the YouTube. If still I am not satisfied I put in the forum. This is the way I work. First two are the quickest way to clear doubt.
Sir do you know it is easy to advice others. In fact it is the easiest job in the world.
Message 4 of 14
steve216586
You have the answer in front of you. There is no need to ask anyone. HELP is a research tool built into Autocad to answer questions like yours.
I don't mind helping, as I've stated before. What I do mind is when there is no effort from the person who is asking. This means you are simply asking for a handout and you will miss out on learning. You might say, "If you tell me, I will remember and so I have learned it." But it is easy to forget when something is handed to you, rather than learning the process which allowed you to find the answer on your own. That is a life lesson well earned and stays with you forever.
I taught for 9 years. The biggest mistake students make, in the learning process, is trying to remember everything instead of learning good research habits. A good teacher never wants you to know everything about the topic, but they do expect you to know where to go, to find the answers.
Here is my research technique advice for your future.
1. Ask tutor. (They reply, probably the same as me, "Go find out for yourself.")
2. Forget Youtube
3. Search HELP in Autocad. (HELP provides definitions, examples and, most times, graphics for procedure.)
4. Google. Screen the results for relevent hits to your topic. Read several if first isn't complete.
5. Search Autocad forum. (Many people may have previously asked the same question.)
6. Ask forum. We are happy to help, unless we feel you are trying to cheat on homework, tests or quizzes.
Message 5 of 14
There are two type of questions.
Straight forward question
If question is about the AutoCAD command. AutoCAD HELP assistance can answer these type of questions.
Questions are coupled with experience
There are questions, answer to these question are coupled with experience only. (For example my last question Explode Vs Ungroup). AutoCAD HELP will not answer these type of questions.
There are YouTube explanations which are excellent. YouTube is an excellent source of explanation if you can find a good one. Because it is with demonstration activating two sensors of the body eye and ear, which is more effective.
I am a member of programing language forum also. Similar question can repeat number of times. What I do is I have a standard answer in my file I modify it to suit a particular question and post it. I do this because I have an interest in the subject and eager to help people.
Message 6 of 14
steve216586
UNGROUP removes all objects from the current group.
The following prompts are displayed.
Select group or [Name]:
If a group contains sub-groups, you are promted to Accept to ungroup the current selection or choose Next to cycle through the groups in the selection set.
To understand UNGROUP the user must understand GROUP:
Group Objects
A group is a saved set of objects that you can select and edit together or separately as needed. Groups provide an easy way to combine drawing elements that you need to manipulate as a unit.
See Also
  • Overview of Groups
  • Create Groups
    In addition to choosing the objects that will become the members of a group, you can give the group a name and description.
  • Select Objects in Groups
    There are several methods for choosing a group, including selecting the group by name or selecting one of the members of the group.
  • Edit Groups
    You can modify groups in a number of ways, including changing their membership, modifying their properties, revising the names and descriptions of groups, and removing them from the drawing.
EXPLODE
 Quick Reference
Breaks a compound object into its component objects.
Access Methods
Button
 Ribbon: Home tabModify panelExplodeNot available on the ribbon in the current workspace
 Menu: Modify ExplodeNot available in menus in the current workspace
 Toolbar: Modify
Summary
Explodes a compound object when you want to modify its components separately. Objects that can be exploded include blocks, polylines, and regions, among others.
The color, linetype, and lineweight of any exploded object might change. Other results differ depending on the type of compound object you're exploding. See the following list of objects that can be exploded and the results for each.
To explode objects and change their properties at the same time, use XPLODE.
NoteIf you're using a script or an ObjectARX® function, you can explode only one object at a time.
2D and Lightweight Polyline
Discards any associated width or tangent information. For wide polylines, the resulting lines and arcs are placed along the center of the polyline.
3D Polyline
Explodes into line segments. Any linetype assigned to the 3D polyline is applied to each resulting line segment.
3D Solid
Explodes planar faces into regions. Nonplanar faces explode into surfaces.
Annotative Objects
Explodes the current scale representation into its constituent parts which are no longer annotative. Other scale representations are removed.
Arc
If within a nonuniformly scaled block, explodes into elliptical arcs.
Block
Removes one grouping level at a time. If a block contains a polyline or a nested block, exploding the block exposes the polyline or nested block object, which must then be exploded to expose its individual objects.
Blocks with equal X, Y, and Z scales explode into their component objects. Blocks with unequal X, Y, and Z scales (nonuniformly scaled blocks) might explode into unexpected objects.
When nonuniformly scaled blocks contain objects that cannot be exploded, they are collected into an anonymous block (named with a “*E” prefix) and referenced with the nonuniform scaling. If all the objects in such a block cannot be exploded, the selected block reference will not be exploded. Body, 3D Solid, and Region entities in a nonuniformly scaled block cannot be exploded.
Exploding a block that contains attributes deletes the attribute values and redisplays the attribute definitions.
Blocks inserted with MINSERT and external references (xrefs) and their dependent blocks cannot be exploded.
Body
Explodes into a single-surface body (nonplanar surfaces), regions, or curves.
Circle
If within a nonuniformly scaled block, explodes into ellipses.
Leaders
Explodes into lines, splines, solids (arrow heads), block inserts (arrow heads, annotation blocks), multiline text, or tolerance objects, depending on the leader.
Mesh Objects
Explodes each face into a separate 3D face object. Color and materials assignments are retained.
Multiline Text
Explodes into text objects.
Multiline
Explodes into lines and arcs.
Polyface Mesh
Explodes one-vertex meshes into a point object. Two-vertex meshes explode into a line. Three-vertex meshes explode into 3D faces.
Region
Explodes into lines, arcs, or splines.
The distinguishing difference between the two is quite apparent after reading and comparing the definitions and usages of each from HELP.
Message 7 of 14
There was an object formed by segment of lines in the drawing. I made segment of lines into one GROUP, after that I try to make it UNGROUP but it didn’t work instead I had to use EXPLODE command to make it UNGROUP. Please explain the reason for it.
This is why I wish to know different between the EXPLODE and UNGROUP command.
Message 8 of 14
steve216586
When you UNGROUP a set of objects, if you look at the command line, you will see: "Group exploded." This is typical.
Message 9 of 14
Yes, what you are saying is correct. I wish to know whether you know the reason why that particular object refuse to explode for UNGROUP command.
Message 10 of 14
steve216586
Check your CUI and report what the macro code is for the UNGROUP command.
Message 11 of 14
dgorsman
I would suggest that you were'nt dealing with a group, more likely a single polyline or possibly a block reference.  Neither of those is a group so UNGROUPing them would naturally not have a result, whereas EXPLODEing them would.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 12 of 14
Wow! What an arrogant, condecending a$$ you are! Instead of trying to get to the root of the person's question, you are basically calling him stupid for not knowing the answer, without yet knowing (or asking for) the specific reason for his question. He didn't ask for a lecture on the research process, he asked a question about Autocad. Maybe internet forum "help" is not your calling.
Message 13 of 14
steve216586
Easy Francis! I've been helping fiatnm through his studies for a while now. Obviously you are not aware but, there is a slight language barrier that we have overcome with familiararity. So while you are busy chastizing me, I will continue to help fiatnm become a competent AutoCad user.
Message 14 of 14
you seem to be trying to make someone feel inferior
you sure come across as a jerk, glad your weren't my teacher
