AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Escape key not working in 2011 Autocad Mechanical
6 REPLIES 6
4489 Views, 6 Replies
Hello Everyone,
I have recently upgraded to Autocad 2011 Mechanical and I have noticed that when I select a line, block, or solid and I try to deselect it by hitting escape.  It will not deselect the object.  I did find on another thread that this has happened on Autocad 2011 MAP 3-D program and that there was a hotfix.  However, I do not think that hotfix applies to Autocad 2011 Mechanical.
Is this a known issue and is there a fix for it?  Thanks in advance for the time.
EDIT:  I have tried the PICKFIRST command as well and it did not work either.
6 REPLIES 6
Thanks for the reply, but based on your response I am assuming I should post my question on that forum?  I searched that forum for my problem and did not find anything that matched it.
jbogaard
Maybe it's got something to do with SP1, because it's one of the issue's mentioned here:
http://forums.autodesk.com/t5/AutoCAD-Mechanical/Autocad-Mechanical-2011-problems-after-installing-U...
Try uninstalling SP1 and see if this helps.
HarryP108
in reply to: jbogaard
I am having the same issue. Installed from the Inventor 2011 Professional discs.
Anyone come up with a fix yet?
Inventor Professional.
Windows 10.
same problem, only I have been running 2011 for months and it just started happening today.
*edit* restart Autocad and I'm back to normal (well, the esc key is back to normal, anyway...)
Re-install the ATI video driver software. http://forums.adobe.com/message/2977659
Kind regards,
Peter Kompier.
”Boost
