What are the steps I should do if I want to use Object Data, the Display Manager, and digitize RUS Imperial? How do I use the Display Manager so that symbols are reasonably visible at Zoom Extents? (FYI: Trying overhead design in AUD. Symbols are different in model-based design compared to regular AutoCAD.)
Use style manager. upper portion is visibility at scales. lower is style of the symbols where symbol by object data, color, size, etc is set.
I am using the Place Pole command in AUD. I want to say that the things in the Display Manager are vector layers. I know how to make a classic layer for the poles but not a vector layer. So I use that pole command, the symbol is too small and the wrong color.
Oh, a layer in the Display Manager are actually called a "Display Manager layer".
