AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Zoom display of symbols
3 REPLIES 3
donald.e.clark
471 Views, 3 Replies
What are the steps I should do if I want to use Object Data, the Display Manager, and digitize RUS Imperial?  How do I use the Display Manager so that symbols are reasonably visible at Zoom Extents?  (FYI:  Trying overhead design in AUD.  Symbols are different in model-based design compared to regular AutoCAD.)
3 REPLIES 3
parkr4st
in reply to: donald.e.clark
Use style manager. upper portion is visibility at scales. lower is style of the symbols where symbol by object data, color, size, etc is set.
donald.e.clark
in reply to: parkr4st
I am using the Place Pole command in AUD.  I want to say that the things in the Display Manager are vector layers.  I know how to make a classic layer for the poles but not a vector layer.  So I use that pole command, the symbol is too small and the wrong color.
Oh, a layer in the Display Manager are actually called a "Display Manager layer".
”Boost
