AutoCAD Map 3D General Discussion
Member
Goxy
Message 1 of 10 (199 Views)
Z coordinates
199 Views, 9 Replies
03-13-2012 02:16 AM
Is there any way to multiply the value of Z coordinate for many points selected, in the same time? For example, I selected many points, and need to double their Z value, but on an easier way, not one by one? Thanks
*Expert Elite*
antoniovinci
Message 2 of 10 (196 Views)
Re: Z coordinates
03-13-2012 03:18 AM in reply to: Goxy
One way is to export those points to a shapefile, then perform the calculation in the .DBF (in Excel or similar), and _MAPIMPORT the edited shapefile back to Autocad.
Member
Goxy
Message 3 of 10 (193 Views)
Re: Z coordinates
03-13-2012 03:25 AM in reply to: Goxy
Thanks a lot. I'll try, and hope it will work, cause I'm beginner in Map 3D. Thanks again.
*Expert Elite*
antoniovinci
Message 4 of 10 (189 Views)
Re: Z coordinates
03-13-2012 03:45 AM in reply to: Goxy
Please pay attention to this point: if you manually edit a .DBF file belonging to a shape-set, you can add or erase columns in the spreadsheet, but it's NOT allowed to add or erase rows.
Valued Mentor
parkr4st
Message 5 of 10 (180 Views)
Re: Z coordinates
03-13-2012 05:31 AM in reply to: antoniovinci
If you only need the calculation, export the pint with the z value as a property, put  the sdf into a map and open the data table, calculate z*2.
Do you need to move the points or create a new set of points at the new z value?
Member
Goxy
Message 6 of 10 (176 Views)
Re: Z coordinates
03-13-2012 07:01 AM in reply to: antoniovinci
Thank you
Member
Goxy
Message 7 of 10 (172 Views)
Re: Z coordinates
03-13-2012 07:17 AM in reply to: parkr4st
Actually, I attended to move plenty of points along the Z axe. To duplicate Z value for all the points in the same time, but as I'm a beginner, didn't know how. I tought, it must be that it is easy. Maybe it actually is, but when you are not familiar with Map 3D, it seems dificult. Now I have some inputs and ideas, so I'll try. Of course, it needs much more time for me. Thanks a lot
Distinguished Mentor
thepworth
Message 8 of 10 (169 Views)
Re: Z coordinates
03-13-2012 07:23 AM in reply to: antoniovinci
I believe that a recent problem with the suggestion of editing a .dbf is that MS Excel 2010 no longer allows you to save back in the DBase IV format.  However, a work-around I found was a gentleman in Australia selling a "add-on" re-enabling this feature for $30 US.
Just want folks to be aware before investing too much labor. :smileyhappy:
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
Product Support
NateMoore
Message 9 of 10 (152 Views)
Re: Z coordinates
03-13-2012 01:45 PM in reply to: thepworth
OpenOffice will allow a save back to .dbf also.(and it's free and will handle the native .xls files as well)
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
thepworth
Message 10 of 10 (150 Views)
Re: Z coordinates
03-13-2012 01:47 PM in reply to: NateMoore
True, thanks for bringing it up - I use it on my personal machine & forgot to mention.... :smileyhappy:
C3D 2011
Post to the Community
New Post
Need installation help?
