When I try to edit a particular Xref in a drawing, I get a message saying:-
Selected Xref Block is NOT editable.
Is there a setting somewhere that controls this?
Cheers
Thanks for your reply Murph.
The Xref file is not read only, so that is not the problem.
Anyone have any other suggestions?
I'm having the same problem. I find that an xref in paper space is editable, however one in model space is not.
Image as in a jpg or bmp? or is it a dwg that is xreferenced into your dwg? Is the one in modle space the same as the one in paper space?
