AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Xref Edit
8 REPLIES 8
Message 1 of 9
Ronaldo54
774 Views, 8 Replies
Xref Edit
When I try to edit a particular Xref in a drawing, I get a message saying:-
Selected Xref Block is NOT editable.
Is there a setting somewhere that controls this?
Cheers
8 REPLIES 8
Message 2 of 9
Murph_Map
in reply to: Ronaldo54
Could be the xref file is set as read only.
Murph
Supporting the troops daily.
Message 3 of 9
Ronaldo54
in reply to: Murph_Map
Thanks for your reply Murph.
The Xref file is not read only, so that is not the problem.
Anyone have any other suggestions?
Message 4 of 9
vette94
I'm having the same problem. I find that an xref in paper space is editable, however one in model space is not.
Message 5 of 9
Murph_Map
in reply to: vette94
What command are you using to edit it and what version?
Murph
Message 6 of 9
vette94
I am using 2013-LT. I have tried double clicking the image, and have also
tried using the edit tool. No luck.
Message 7 of 9
Murph_Map
Image as in a jpg or bmp? or is it a dwg that is xreferenced into your dwg? Is the one in modle space the same as the one in paper space?
Murph
Message 8 of 9
vette94
It's a dwg xref'd into model space and viewed through a viewport in paper
space. I've tried editing through the vport and, changing to model space
and editing. No luck.
Message 9 of 9
Murph_Map
Is the layer for the xref lock in the viewport?
Murph
”Boost
