AutoCAD Map 3D General Discussion
Active Member
North9ON
Message 1 of 7 (668 Views)
Xref Disappears on Zoom In (Map 3D 2011)
668 Views, 6 Replies
01-19-2012 06:11 AM
I have a georeferenced drawing with aerial photos and linework that I have Xref'd in a recent survey drawing. I checked that the coordinate systems match and the xref shows that it is loaded and the layers are listed as on and thawed.
However, the xref is not visible.
I tried a new blank drawing using the Map 3D template, same coordinate system. Same thing happens. However, this time, I noticed that the xref is visible when zoomed out. When I zoom in, it disappears. Screen shot attached.
It is set to parallel. But, you gave me another idea!
If I switch to 2D view rather than 3D, the problem seems to go away. Now, I need to check my original drawing.
Thanks.
Well, setting the drawing to 2D view solved the problem. I didn't try anything else due to time constraints.
Distinguished Mentor
thepworth
Message 2 of 7 (656 Views)
Re: Xref Disappears on Zoom In (Map 3D 2011)
01-19-2012 12:24 PM in reply to: North9ON
looks like your Autocad view setup is for a 3D orientation instead of 2D top down, but the view cube doesn't show in the screenshot.  My "guess" is based on seeing a section of the Z axis in your crosshairs.
Unless you go to 3D viewing from the Map Status bar at the bottom of the screen, sometimes using the "vanilla" autocad 3D view settings can cause issues.
Just a guess, but let's see if anyone has $.02....
TdH
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
Active Member
North9ON
Message 3 of 7 (653 Views)
01-19-2012 12:37 PM in reply to: thepworth
I've attached an updated screenshot showing the view cube.
To me, it seems like AutoCAD is hiding the xref at a particular zoom level. If I use my mouse wheel to zoom in and out, the xref appears and disappears.
thepworth
Message 4 of 7 (649 Views)
01-19-2012 12:40 PM in reply to: North9ON
humor me with this one - in the lower right of the viewcube is a dropdown arrow.  expand the flyout and see if it's set to perspective or parallel.  should be parallel.
beyond this, unless someone set a zoom scale on it (very unlikely), i'm not sure what else to try :smileysad:
C3D 2011
Active Member
North9ON
Message 5 of 7 (646 Views)
01-19-2012 12:44 PM in reply to: thepworth
Thanks.
Alfred.NESWADBA
Message 6 of 7 (629 Views)
01-20-2012 12:37 AM in reply to: North9ON
What happens if you copy&paste it (complete modelspace content) into a new drawing and run then ZOOM?
Question 2: have you set some scale-handling in the MAPWSPACE-dialog?
- alfred -
Alfred NESWADBA
Active Member
North9ON
Message 7 of 7 (625 Views)
01-20-2012 05:24 AM in reply to: Alfred.NESWADBA
