Jeff,
It looks like some operation in the drawing is attempting to save Xdata
(extended entity data) to the objects and its size exceeeds the limit of 16 K.
I can suggest one solution - but try it first on a backup copy of your drawing.
Using our GeoTools program (see link below for download), you can run the REM_XD
command and try and remove all or selected extended entity data information,
save the drawing and see if it makes a difference. If everything else works
fine, you can use this drawing else we may have to examine your file in detail
to see what is offending it?
Are you using any thiry party programs that may be adding Xdata to your objects?
Regards
Rakesh
Jeff Wood wrote:
> I have a 182k drawing with two polygon topologies and keeps bringing up this
> error message:
> "An error occurred while saving the project.
> Cannot save options in the drawing.
> XData size exceeds 16K limit."
> Doesn't seem to affect the drawing at all and recovery doesn't make any
> difference - just annoying!
> I would be grateful for any assistance.
> Regards,
> Jeff Wood
> Bennett & Francis
> Direct ph +617 3239 5403
> Direct fax +617 3239 5413
> Mobile 0419 888 367
> www.bfsurveys.com.au
AutoCAD customization for Engineering/Mapping/GIS
Get GeoTools @ http://www.4d-technologies.com/geotools
Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm
FREE downloads : http://www.4d-technologies.com/techcenter
