"JWCI" wrote in messageI'm
href="news:6103725@discussion.autodesk.com">news:6103725@discussion.autodesk.com...
very new to map, limited experience, looking to write an expression for a GPS
object that will include Pt #, Northing, Easting, Elevation seperate lines of
text, I can currently view one property text at a time, ie. Pt #, How can I
edit the expression below to achieve a multiline expression with Pt,N,E,El.
Any help would be greatly appreciated. CONCAT ( CONCAT ( CONCAT ( [property],
'\n' ), 'Label: ' ), [property] ) Greg M.
I just get a single line label with this expression... any ideas what i'm doing wrong?
CONCAT ( CONCAT ( Name , '\n', AreaX ) , '\n', C )
Does it not work? Do you get a message (or where is the cursor when it tells you that there is a syntax error, a screenshot might be great)?
It's hard for us to guess, we don't see the data you have ... so e.g. if your C is a field in the datasource or your just wamt to have the character "C" as prefix.
Is AreaX as field with double values or string values (if it's a double value then try to convert it to string before concatening it).
Good luck, - alfred -
There is no need to use multiple CONCAT functions in one expression, just one:
CONCAT(Northing, '\n', Easting, '\n', Pt) and thats it, you got three line text.
