AutoCAD Map 3D General Discussion
Active Contributor
amm30165
Message 1 of 8 (1,255 Views)
WORLD UCS ROTATED
1255 Views, 7 Replies
08-31-2012 08:36 AM
The World UCS seems to be rotated for some unknown reason.
If I change it to Plan view everything seems fine but it still bothers me.
I have not used dview twist; it is set to 0.
This seems to be an issue since I updated to Map3D 2013 64bit.
Is anyone else having this problem?
Thanks!
Alicia
can you verify the sysvars
UCSFOLLOW (should be tried with 0)
if you start _GEOGRAPHICLOCATION ... are you asked for removing a geogr.position? If so answer with "remove" and look again to your drawing with _PLAN _WORLD or press onto "TOP" on your viewcube.
If none of these options work, please click on "TOP" and let us see the screenshot then.
- alfred -
Alfred.NESWADBA
Message 2 of 8 (1,252 Views)
Re: WORLD UCS ROTATED
08-31-2012 09:00 AM in reply to: amm30165
The WORLD coordinate-system within a drawing can't be rotated or modified in any way. Why do you think that it is rotated?
If you open a drawing in 2013 what is different to the previous AutoCAD Map3D you had?
- alfred -
Alfred NESWADBA
Active Contributor
amm30165
Message 3 of 8 (1,251 Views)
08-31-2012 09:06 AM in reply to: Alfred.NESWADBA
The view cube in the upper right hand corner (with North, South, East and West) is not straight.; looks rotated about 10 degrees to the NE.
Alicia
Alfred.NESWADBA
Message 4 of 8 (1,248 Views)
08-31-2012 09:19 AM in reply to: amm30165
if UCS is really set to WORLD, then your view is twisted, not the world-coord is rotated. It's just like you rotate your head, that does not rotate the world :smileywink: :smileywink:
Well, you said it, command _PLAN and option _WORLD and you look parallel to world ucs (north is up).
- alfred -
Alfred NESWADBA
antoniovinci
Message 5 of 8 (1,241 Views)
08-31-2012 10:02 AM in reply to: Alfred.NESWADBA
Yep, or more simply: type in _UCS and double enter...
Active Contributor
amm30165
Message 6 of 8 (1,235 Views)
08-31-2012 10:30 AM in reply to: antoniovinci
I appreciate all of the replies.
I have been working with AutoCAD for 20+ years and have not experienced this before.
Maybe the attached png will help to explain my problem....
Why does the view cube look exactly the same in every drawing I open?
The ucs icon is squared up and not a named or object aligned ucs; the view has not been twisted.
My drawings did not look like this when they were saved to a version provious to 2013.
Did I unknowingly change a setting to something?
thanks,
Alicia
Alfred.NESWADBA
Message 7 of 8 (1,230 Views)
08-31-2012 10:40 AM in reply to: amm30165
- alfred -
Alfred NESWADBA
Active Contributor
amm30165
Message 8 of 8 (1,227 Views)
08-31-2012 10:52 AM in reply to: Alfred.NESWADBA
Removing the current geographioclocation fixed the world UCS.  Everything is squared up again.
Thanks so much!!!
I appreciate your patience.
Alicia
