AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
World Files Not Recognised
18 REPLIES 18
Message 1 of 19
Neil47
6025 Views, 18 Replies
I am trying to insert Geo-referenced TIF files into Map 2013 but the associated World files are not being found/recognised even though they are in the same directory as the image. I have tried both TAB and TFW using MAPIINSERTand Data Connect.
Going back to Map 2012, which we still have in the office, the World files are found and correlated correctly with both of the above World file types and Map commands.
I can do what I need to do in 2012 for the moment but has anyone else had this problem?
18 REPLIES 18
Message 2 of 19
antoniovinci
in reply to: Neil47
Try to embed the .TFW file in the header of your .TIF, by means of the free GeoTiffExaminer tool, sir.
Message 3 of 19
Neil47
in reply to: antoniovinci
Thanks for the tip, it's a nice tool and has provided a work round for the problem I'm having although I'd still like to know why Map was not finding the world files.
Message 4 of 19
antoniovinci
in reply to: Neil47
Feel free to paste here the content of that Worldfile, thanx.
Message 5 of 19
Neil47
As noted in my first post these are both found and used by Map 2012 to locate the raster file correctly but not by Map 2013 - hopefully thwe layout of the contents isn't lost in the formatting of the post
Contents of TFW file are
1.000000000000000
0.000000000000000
0.000000000000000
-1.000000000000000
335000.500000000000000
134999.500000000000000
And contents of TAB file are
!table
!version 300
!charset WindowsLatin1
Definition Table
  File "ST33SE.TIF"
  Type "RASTER"
  (335000,130000) (0,5000) Label "Pt 1",
  (340000,130000) (5000,5000) Label "Pt 2",
  (340000,135000) (5000,0) Label "Pt 3",
  (335000,135000) (0,0) Label "Pt 4"
  CoordSys Earth Projection 8, 79, "m", -2, 49, 0.9996012717, 400000, -100000
  Units "m"
Message 6 of 19
antoniovinci
in reply to: Neil47
Are you REALLY sure that .TFW file name is ST33SE like its own TIFF ?
If so, erase or move the original .TFW anywhere, then with GeoTiffExaminer recreate it from the Geotiff already existing, and try again in Map2013.
Message 7 of 19
alberto00
in reply to: Neil47
The same thing happened to mee too...
Georeferended .tif image in the right position with civil 3d 2012. .tfw file not recognized in civil 3d 2013....
Message 8 of 19
andreas_kluser
in reply to: Neil47
Same thing happened to me too with Civil 3D 2013.
My problem was that the path to the *.tif and *.tfw was too long (or spaces ...). Putting the two files to c:\temp\ solved the problem.
Message 9 of 19
surveyor8120
in reply to: Neil47
I am having the same problem with Civil3D 2013.
If i change the coordinate system of my drawing to no projection no datum, it will come in just fine.  However if i do not it will come in the wrong place.
I have an geotiff that is in Alaska Stateplane zone 7 (NAD83)  and my current drawing is a custom coordinate system with defined values in Autocadd.
I normally in the past would just edit the world file to make the geotiff come in my drawing in the correct place.  However when I do this it will not work, put it in wrong place.  I notice on the insertion that the correlation data is different than my world file.
 If i change my coordinate system to no datum no projection it will come in to the correct place and the correlation data on the import is same as my world file.
So looks like to me that it is trying to convert on the import.
So what should i do, is there a setting I need to change in Civil 3d / Map?
Anthony Robinson
arobinson@crweng.com
Anthony Robinson, PLS, CFEDS
CRW Engineering Group, LLC
Civil 3D 2015
Windows 7 Prof. x64 SP1
Dell Workstation
Intel(R) Core(TM) i7 CPU
870 @ 2.93GHz
16.00 GB RAM
Message 10 of 19
surveyor8120
in reply to: surveyor8120
I opened my image in a photo viewer then saved as a regular tiff and now Civil3d 2013 will now read the world file and bring it in correct location.
So seems to me that Civil3d 2013 is trying to read my image info instead of world file info?  Which is not the order it is supposed to.  What do you guys think?
Anthony Robinson
arobinson@crewng.com
Civil 3D 2015
Dell Workstation
870 @ 2.93GHz
16.00 GB RAM
Message 11 of 19
antoniovinci
Yes Sir, first Autocad checks whether the Geotiff embeds a geo-header, if not, it reads and use the .TFW worldfile.
Message 12 of 19
Well having the same problem...
If you resave the jpeg it kills the header... but still shouldn't the MAPIINSERT method allow you to chose the correlation source??? i can't see "world file"?
annoying as hell... considering even the most frighteningly old program like FWtools can read the header in the jpeg. But i guess Map 3D is pretty crusty itself!!
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Message 13 of 19
Should i quickly add that resaving the Jpeg its also reduces the quality of the image!!
Infraworks 2021.1,
ceethreedee.com
Message 14 of 19
You can extract the worldfile from a Geotiff, by means of the above mentioned tool by Mentor Software.
You wrote you have JPGs with embedded geo-headers: are you talking about the JPEG2000 format?
If so, could you attach here one of your GeoJPEGs..?
Thanx in advance, sir.
Message 15 of 19
Thanks antoni... but just realised i had a different problem!!
If your folder path to your image is greater than 128 character it does not read the world file!!!!
Try it....
The image was stored deep in a large project for us, as soon as i pulled it back to the base of the project directory everything works. Try it
Infraworks 2021.1,
ceethreedee.com
Message 16 of 19
So that conrifms my map 3d is crusty statement!!
Infraworks 2021.1,
ceethreedee.com
Message 17 of 19
I don't think so, sir: the problem is in the nature of your attached file, which doesn't embed any header.
It's not a "special" GeoJPEG, but only a normal, classic .JPG with external worldfile, period.
I converted to a "true" 8-bit Geotiff - check the attachment out.
My advice is: if you handle orthophotos, don't the lossy (and "stupid") JPEG format, but only the TIFF one (lossless and "geo-clever").
Message 18 of 19
Yes i removed the header from the jpeg.
As mentioned before i have a different problem. Map 3D doesnt read the world file when the folder path is longer than 128 characters.
So i had my jpeg stored in the following folder path
"K:\Des\2010\107635002 QGC Associated Water Chinchilla\Task 14000 Decommissioning\14200 - Woleebee Creek Pond\XREFS\Nearmap"
When i moved it to
"K:\Des\2010\107635002 QGC Associated Water Chinchilla\Imagery Data\"
It then read the wolrd file!!!
So some people out there may run into the same problem, here is the solution
Infraworks 2021.1,
ceethreedee.com
Message 19 of 19
Here's another one, vintage but evergreen:
C:\> SUBST Q: "K:\Des\2010\107635002 QGC Associated Water Chinchilla\Task 14000 Decommissioning\14200 - Woleebee Creek Pond\XREFS\Nearmap"
now you could be able to load your imagery from "Q" virtual partition, i.e. from a very short Q:\ path
”Boost
