AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
world file .tfwx
5 REPLIES 5
rmacan
1192 Views, 5 Replies
world file .tfwx
Does anyone have an idea how would I insert a *.tiff image with a world file that is *.tfwx into MAP 2014?
MAP appears to ignore it.
5 REPLIES 5
Alfred.NESWADBA
in reply to: rmacan
I would rename the file from TFWX to TFW and try it again, it that does not help, can you upload that TFWX file so we can look into it?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
vladimir_michl
in reply to: rmacan
.TFWX files contain approximate affine transformation data (when the original transformation cannot be exactly expressed as affine). Just rename this world file to .TFW and load/reference it with your TIFF file using IINSERT or GeoRefImg. This is the best approximation in AutoCAD or AutoCAD Map.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
rmacan
in reply to: vladimir_michl
Thanks for the responses.  Yes, upon getting a reply from the source of the files, it appears that the images aren't really rubbersheeted, so the world file was approximate.  This seems to be ESRI's way of identifying that.  Since I need to delineate from them, I'll go ahead and rubbersheet them more accurately.
So I learned something today.
Thanks again!
Randy
vladimir.michl wrote:
.Just rename this world file to .TFW
 Already written by Herr Alfred, sir.
 Are you meaning _MAPIINSERT or what else, sir?
Yes, any command supporting "world" georeference files can be used - IINSERT, MAPIINSERT, GEOREFIMG...
”Boost
