I have set up my workspace as i like it, & saved it as 2013, then ticked it as current.
When i close then open Map 3D 2013, the workspace has switched to planning & analysis
workspace, which has mysteriously become ticked.
Can anyone help please, thanks in advance
You must change in "Workspace settings" Switching parameter to "Automatically save workspace changes"
Yeah, I've done all that, still does not save when I close then reopen ACAD!!!!
Then attempt to open "Customize User Inteface" window and there on the workspace style which you want right click and set "Set current".
Hasn't worked either, but thanks anyway. Don't know why they make things so difficult!!!!
In 2012 this was quite common. If you still can't get it to stay as set, the startup switch options here might help: http://gisexchange.typepad.com/blog/2011/05/map-2012-default-workspaces.html (also be sure that you have all the updates applied).
>> i have tried everything and still no good.
Also the answer(s) in >>>the other thread<<< you started ....?
- alfred -
Is this a known bug that they are working on? I have the exact same problem, it will not remember the current workspace like it's supposed to. Instead it resets to the default one constantly. This normally wouldn't be a huge issue, as you could just change your profile to the default in cui, but we have multiple users sharing one profile and creating their own custom workspaces. The way it worked in 2011 Map 3D was that once they set theirs to current it would load it instead of the default everytime AutoCAD was opened (and I believe this is how it is supposed to function).
