AutoCAD Map 3D General Discussion
Active Contributor
Jfactory
Message 1 of 3 (185 Views)
Working with a DEM
185 Views, 2 Replies
07-23-2013 11:11 AM
Hi. I once had a similar question but this time my data is smaller and much better.
I'm hoping to figure out a few things about DEM's.
1) vertical exaggeration - what to set it to? Is there data for a Z-scale I'm missing?
2) how to move a DEM as mine isn't located in the right spot.
3) better overall understanding of working with DEMs
The DEM data comes from this website: I tried attaching a 10 MB zip but it was too big.
http://www.dggs.alaska.gov/pubs/id/23964
When I data connected to the DEM which is in ASCII format it comes in looking okay.
DEM connected
Then I change to 3D mode and it's terrible.
3D view not working
For a while I decided it was my data and I should convert it in ArcGIS... but first I decided to play with vertical exaggeration.
Setting vertical exaggeration to .00001 yields this:
Now it's looking good
And I'm satisfied with the way it looks now, but I'm curious why the vertical exaggeration is whack?
Also, the section is way off from my other data. How can I move it?
Strangely, it seems to work correctly in ArcGIS. Does anyone know any solution I could fix in ArcGIS and then transfer it to AutoCAD? I mainly use AutoCAD.
Active Contributor
Jfactory
Message 2 of 3 (182 Views)
Re: Working with a DEM
07-23-2013 11:23 AM in reply to: Jfactory
Additionally, it came with shp files as borders and they're located in the right spot...
How do I connect them?
Active Contributor
Jfactory
Message 3 of 3 (177 Views)
07-23-2013 11:28 AM in reply to: Jfactory
Omg, I think I fixed it. It was allllll because of the coordinates!  Silly me! Sorry for the trouble!
