AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
WMS Map scale problem
3 REPLIES 3
454 Views, 3 Replies
I have a problem where as after I  connect and attach a map via WMS and I measure road ways. everything is 1/3 the size it should be ( a 12' wide lane measure  4units (feet))
I open a new DWG,
I connect to my WMS provider, set Server CS Code to "EPSG:3857" and click "add to Map"
check the distances and its at 1/3 of actual size.
Can anyone help point me in the right direction?
3 REPLIES 3
Alfred.NESWADBA
welcome @forums.autodesk.com !
Is it a free WMS service? If so let us know what server that is (how to access it) + let us know what you have set as units in the _UNITS dialog? So we can try ourselves.
The version of Map3D (and servicepack) you are using might be helpful too.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
I am using Map 2012 SP1, with MapSavvy (has a free trial).
_Units:
Decimal Length
Insert Units:
Ive tried Unitless and Feet with the same results
http://www.onterrasystems.com/web-mapping-mapsavvy/
Thanks for any insights.
I try assigning a cordinate system (us survey foot) but the cordinate transformation always fails.
”Boost
