I'm trying something I believe to be fairly basic: I'm trying to get some basemapping into my Map 3D drawing.
In particular, I need to get the World Street Map found here: http://www.arcgis.com/home/item.html?id=3b93337983e9436f8db950e38a8629af
In Map, under Data Connections, I'm using "Add WMS Connection"
I give the connection a name, enter the Server name, and leave Version on "Default version"
I leave username and password blank.
But I always get the error message: "Failed to connect."
Any ideas? Do ESRI and AutoCAD just not play well together?
This basemap is not a "WMS service". So you can not add it with an FDO WMS conection.
This basemap is an "ArcGIS image service".
Jens
I don't understand all that FDO connection stuff. A smart guy at CADSoft pointed me to Basejump, which is awesome, just what I needed.
