AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Will Project Basejump work with AutoCad Map 3D 2012
3 REPLIES 3
ssirianni
317 Views, 3 Replies
Hi, I currently have AutoCad Map 2012 and want to try Project Basejump to replace Google Earth. I noticed that Basejump is ment to be used with 2013 version .but will it work with 2012 version???
3 REPLIES 3
DarrenP
in reply to: ssirianni
you can try it but i don't think so
download and try to install it
DarrenP
ssirianni
Thanks, i will try it
phil_borycens
Basejump was designed for AutoCAD Map/Civil 3D 2013, so unless you have strong 'hacker' skills, you probably won't be able to get it to run on 2012 🙂
http://labs.autodesk.com/utilities/basejump/
Phil Borycens
”Boost
